I received permission from Matt Cox to post this to the forum. This is good news!!! - Perry
Hello,
Thank you for your interest in, and patience regarding, the alloy cylinder head. We are getting close to getting them. I received an update from the foundry last week. Due to the length of time since the last order, there was a delay getting the intake and exhaust runners made. This has caused the timing to slip by about one month. There will be some time required for final assembly as well. I now hope to begin shipping by the end of March. Once the final assembly is done on each head, I will be shipping them. I will not be waiting until all are ready. Orders will be filled on a first come, first served basis, unless there are special instructions that may delay final assembly.
In order to ensure I have adequate supplies of optional and incidental parts, please let me know if you intend to order any of the following with your alloy head:
You will also need to select the valve springs. This chart will help you make your decision:
This is not an upsell pitch. I hope some of you buy additional parts, but I truly want to make sure I have no delays after the heads become available so I want to order ahead.
Some of you have made certain special requests. Please repeat those requests in your reply.
Thank you very much for your order and your patience. I know this is going to be worth it!
Matt Cox
586-663-1966
http://vintageinlines.com
Hello,
- Head gasket set
- Engine gasket set
- ARP stud kit- Full kit or Partial kit (for those who already have studs on a cast iron head)
- Rocker arm assembly- stock adjustable, 1.6 ratio stock style, Yella Terra full roller
- Alloy valve cover-including oil fill plugs, breathers, or PCV options
- Weber carburetor- 32/36 or 38/38
- Lokar pedal (where available) and throttle/kickdown cables
- Header (includes stainless header stud kit and Classic Inlines style gasket)
- Engine rebuild parts- pistons, bearings, gaskets, etc
- DUI/Duraspark II distributor
- Camshaft (please specify)
- Dress up- Billet thermostat housing, water pump pulley (1V or 2V) natural or polished finish
- Custom head work will be available on request. There will be Street and Street/Strip levels. Details and pricing are not finalized. Due to all work being done at one shop, there will be slight delays based on demand.
Matt Cox
586-663-1966
