ssg66stang
Hi everyone, this is my first post to this forum and I hoping that I gain a ton of knowledge from you more experienced folks.I'll try to make this post as short as possible and still give you the information that I believe you need, in hopes of you giving me some advice.
I have a '66 coupe with a 200cid block and 250 head. I have had this car since highschool,when the head was replaced (a friends father was helping me with the car but i dont know what all was done to the head). Last week, I finally got the car running again and I noticed smoke coming from one of my breather caps. I pulled the head and found that I have a chipped intake valve on cylinder #5. I took the head to a recommended shop and they will be doing some head work. I asked them to cc the chambers and mill what was necessary to get my C/R to 9:1-9.5:1, replace the valves, do a 3 angle valve job, replace seals, guides, etc as necessary. Eventually I might put a mild cam in this motor (any suggestions??). What are your thoughts and recommendations with this setup? Is there anything else that I can ask the machine shop to do that will get me some Hp/Tq gains?
Modifications that I have completed:
Long tube headers with "x" pipe, 2.25" pipes and Borla Pro XS mufflers, Weber 38 2bbl, Ford 8" rear end with 3.25 gears, front disc brakes
Once the motor is back together I plan on upgrading the distributor...Any suggestions?
Thanks in advance
Thanks in advance
