I'm just trying to wrap my head around vacuum advance and high performance.
More vacuum pulls the diaphram and makes the spark happen earlier ( advanced).
If vacuum is higher at idle it seems the advance will be higher then, so if I slam the pedal down, vacuum drops a lot, we lose the vacuum signal and we lose some advance as
well ? Isn't this when we want the timing advanced the most ?
Does centrifugal ( mechanical ) advance make up for the lost vacuum advance ?
DannyG
DannyG
