Why Upgrade Your Ignition?
The stock Ford inline six used a breaker-point ignition system that was adequate for its era but has real limitations for modern performance use. Points wear, require periodic adjustment, and struggle to maintain a consistent spark at higher RPM. Upgrading to an electronic ignition — whether through a drop-in module (Pertronix), a GM HEI conversion, or a purpose-built distributor — is one of the highest-value, lowest-cost upgrades available...
