It may work although 1904 was used on the 144/170 mostly? There are carb experts on here that will know. The 200 can use more cfm for maximum performance and it will need to be compatible with the LOM. Just checked my Falcon Performance Handbook and found that the Autolite 1101 early versions were compatible with the LOM. Was used on 60s Ford 223. The throttle bore is larger so you would have to modify the opening with a dremel or something.So I’m getting the gist that swapping in a 64 200 isn’t quite as simple as I thought unless the Holley 1904 and distributor from the 144 would work?
