Howdy Back Matt and All:
I think Mike is very close to an accurate estimation of HP/torque increase for a slight increase in valve lift.
I do have to clarify Mikes statements a little. He said "the lifter opens a little higher and a little faster (adds approximately 3 degrees to the valve duration)".
I think he meant the valves open a little higher. The lifter follow the lift on the cam lobe. The rocker multiplies that lift.
The rockers don't change the duration on the cam. They will change increase duration slightly at .050" of lift since they open the valve slightly faster. Duration measured at .050" of valve lift is the standard of measure for most performance cam manufacture.
I also agree with Mike on the value of a Dual roller timing chain cam drive.
Matt- given your engines level of stockness, it would make sense to seek increased engine performance by using a bolt-on enhancement like the 1.6:1 rockers. They will require little wrenching and no tuning at all. Personally I'd go with the stock type with your engine package.
A reground cam does not comprise cam lift. It just changes the base diameter of the cam lobes. Lift remains the same.
Your butt-o-meter will have to be fairly sensitive to feel the difference.
Yes, a rich mixture will slow the car down. It also waste expensive fuel. A well tuned Air/Fuel mixture is a happy mix. Too lean is also bad for performance, runs hot and hard on an engine.
That's my two cents.
