Pinhead":387fhkn6 said:Jaylo":387fhkn6 said:I was responding to crashbox455's idiotic posts on page 1 and then I realized that they were from 2005.Lazy JW":387fhkn6 said:
Why? Technically he is right... Heat and temperature are two different thigns...
crashbox455":387fhkn6 said:the compression stroke doesn't increase heat- it moves the heat from the mixture into the cylinder- your engine's water temp goes up, but the mixture actually loses heat. the increased pressure causes some of the HC's to re-condense into liquids. so don't go crazy with the compression.
Technically he is wrong. This is compounded by the fact that he uses the ideal gas law in another post to try and prove his point when, in fact, he only disproves it.
First,
PV=nRT
This tells us that as pressure goes up, temperature goes up in a closed system (compression stroke).
What he complete neglects is the fact that Q (heat) = m (mass of charge) x cp (specific heats or air and fuel) x DeltaT (temperature difference from compressing from BDC to TDC)
Since no real world system is adiabatic, yes some heat of compression is lost to the cylinder block, piston and head and thus wasted. But in no way does the mixture have a net lose of heat in this process.
If he somehow discovered how to do work on a fluid without increasing its heat, I’d love to hear about it. That is totally absurd.
Didn’t you guys pay attention in Thermodynamics, Combustion Theory, and IC Engines in college?
Pinhead":387fhkn6 said:Heat: added or external energy that causes a rise in temperature, expansion, evaporation, or other physical change
Temperature: a measure of the warmth or coldness of an object or substance with reference to some standard value. The temperature of two systems is the same when the systems are in thermal equilibrium
Heat causes the temperature change. The reason they're not the same is because different substances can absorb different amounts of heat (joules) before their temperature (degrees) will change (specific heat, anyone?). In other words, dump a certain amount of heat into water, and dump that same amount of heat into metal, and tell me which substance's temperature rises more quickly. Water has a much higher "specific heat" than metal.
Thanks. I gathered that much back in high school chemistry. Those realities only prove my point. Please see aforementioned.
Pinhead":387fhkn6 said:Also, there is another fallacy that is being spread on numerous forums, including this one. It's the old "lean mixtures burn hotter" argument. THIS IS NOT TRUE. Gasoline burns "hottest" (puts out the most thermal energy) at 14.7:1. The reason the engine runs hotter when it's running lean is because the air/fuel burns more slowly. There is more time for the thermal energy to be transfered into the engine. This is also why your horsepower drops so quickly when running lean (you don't take away X amount of chemical energy in your fuel for the same amount of energy loss at the crankshaft). This is because more energy is being lost into the engine instead of pushing down on the pistons.
That is absolutely wrong. It is not a fallacy. The stoichometric ratio is only used to balance the reaction equation. Lean mixtures (to a degree, not excessively lean ones) burn hotter because the chemical reaction takes place in excess oxygen, thus bringing combustion efficiency much closer to 100%. This is quantifiable and measurable in how much N2 (which is normally an inert gas) is consumed due to the higher combustion temps. N2 doesn’t do jack until reaction temps of around 1600º F.
I have no idea who promulgated the idea on here that fuel some how needs or even is cooled before it burns. The exact opposite occurs. Fuel is heated up in steps from the time it enters the fuel pump and is injected into the intake runner and then compressed in the cylinder. All of these processes add heat to the fuel. At no time (unless someone is using a ghetto draw through turbo turbocharger with intercooler) is the fuel cooled.Pinhead":387fhkn6 said:An engine that is overly rich will run cooler only because it takes some amount of energy to evaporate the cool liquid fuel before it will burn (but this not only makes it run cooler, it slows the burn). This is a complete waste of energy, though with most cylinder head designs is completely warranted to keep from burning exhaust valves, etc. This again is due to the "slow burn" nature of the cylinder heads, along with relatively low compression ratio (and thus expansion ratio).
This is what I was responding to which I “…†out after the fact when I realized how old the post was.
