170 exhaust manifold
I am sure that this question has been asked and answered before-however I am having trouble finding topics using the "search" process.
My daughter's 61 comet developed an exhaust leak shortly after engine rebuild (approx. 700 miles). I had the manifold surfaced flat while at the rebuilders-however I can now see a couple of cracks in the manifold (casting now too thin?) and have purchased another manifold.
I only have approx. half of the original 3-tab lock washers and cannot locate replacements.
Will common split lock washers work?
Is there a loc-tite product made for hi-temp exhaust applications?
Any other advic would be very much appreciated.
Thanx
Dave
I've always replaced exhaust manifold bolts with either Grade 8 or other known high-quality bolts (ARP), and have used the matching split lockwashers without trouble.
It's not unusual to have to re-tighten then after several heat/cool cycles, usually around 100-200 miles I'll wrench them again.
I don't think there's a high-temp locktite...I know that to loosen the strongest locktite, you heat it first. I'm not sure I'd locktite a manifold bolt anyway, seems like a good way to ensure snapped bolts in the future.
I'd stick to good fasteners and split lockwashers, or maybe make some locking tabs.
Thanx for the tip-used grade 8 bolts and washers and re-torqued a couple of times. No leaks-problem solved.
