Since 144 pistons are hard to find, will the 170 pistons work in the 144 engine since the bores are the same? The 170 piston skirts are modified to clear the stroked crank in the larger engine but it seems that the different skirts shouldn't be an issue in the 144. If the 170 pistons indeed work in the 144, should all the pistons be replaced or just the one I (ahem) broke trying to get it unstuck? Are the wrist pins and height on the two pistons the same? Do they weigh the same?
