Thanks, Bubba. I've put about 20,000 miles on it since the Sept 2018 post. I really enjoy driving it.
One of the cons of turbos is the requirement for good, detonation-resistant fuel. One of my goals is better MPG, so forcing me to use premium fuel defeats the goal. I'm going to try to run 87 octane. I may need to lower compression, add aftercooling, and add knock-sensing.
To start with, I'm going to lower boost.
The stock wastegate is set at 10 psi. Wastegate-controlled boost pressure is set by the tension of the wastegate spring. Fancy wastegates allow the spring to be changed, I chose to oppose the internal spring with an external one.
Rig for checking wastegate opening pressure...
Hoping for 6-7 psi when I'm done. That should be good for at least 35 HP/45 ft-lbs, hopefully on 87 octane.
