Wow, going on two years later and this project is finally completed (for now). Little things like floor pan repairs and a rear end swap got in the way. Actually had always intended to do this project somewhat in conjuction with the 8in rear end swap since the old system was rusting out and was a hodge podge of a C3, 1.75" manifold and 1.75" pipe going only as far back as the muffler. Then just ahead of the old muffler it changed to a 2in nipple leading into a 2" tranverse hung muffler that exited out the driver's side.
Anywho, I ended up going with the 68 (C8 or 'X') manifold as mentioned, and the 68 head pipe (2 inch). I used the intermediate pipe and tail pipe from a 289 dual setup...2 inch all the way back now. I also added an inexpensive resonator for the time being to cut down the raspy/ricey sounds. The results are 'under-whelming' compared to those with headers and a non-stock cam, but I'm satisfied.
I got the $14 Jones resonator from Summit figuring the shortest length version would make least impact on flow, and then played with installing it two different directions (first with louvers/scoops going with the flow, then with them facing into the flow...as intended to be used AFAIK).
Folks at Jones Exhaust were very helpful and said that the first method would give the best flow and the second would give the best sound attenuation. I had originally planned on putting the resonator upstream of the muffler at a low spot where the 68 head pipe met the 66 dual/intermediate pipe (an apparent unwanted side effect of mis-matching stock pieces). I ended up deciding to put in after the muffler figuring it would impact flow less; since in theory exhuast gas would be more fully expanded and velocity would be lower at this point (prolly lessened the sound effect as well though).
And the results...[note: prepare to be un-impressed if you've got anything other than stock...ie headers, cam, 2bbl, etc....but I'm happy with it]
First is straight pipe after turbo muffler, then resonator with flow, then resonator against/into flow, then the final result
Straight pipe after muffler
Resonator with flow
Resonator into/against flow
Final with 2 to 2.25 ss tip
As cautioned it's not dramatic, and things like the straight pipe coming up short of the rear valance in the first clip, or moving the camera in the final clip may make it difficult to tell the difference...but the difference in person and driving down the road is about what I was hoping for, which is good by me. Obviously, it wasn't like it's a big deal project, but having finally gotten it done last weekend inspite of the Tx heat...
...is at least one more item off the list.
It was actually cool to post to this old thread because it helped me kinda reassess my long term plans. A slightly modified stocker, or following the FFPH now what's left to consider is a 3 angle valve job & backcut along with possibly high ratio rockers=$$$
