Use the better gasket.I thought the felpro gaskets are .050 crush? Or are you referencing the victor gasket?
Really?!?! I might not have to use premium??? This is a great moment haha.
My reply glitched. See the last post on pg 2Use the better gasket.
What does that measurement give me? Centerline to deck? I don't follow.Your calculations are correct.
The best thing to do is measure the actual deck height.
If you have a 12" caliper, measure from the top of the main bore to the block deck and add 1/2 the main bore diameter.
You certainly can increase the chamber volume by unshrouding the valves.
I like to bolt the head to the bare block and scribe the cylinder bore circle on the head surface for a guideline.
Do not use the head gasket for template.
Quench distance is important, i was thinking about that actually how the aussie pistons would help that a lot. Why is it then that milling the head screws up the quench, but having the piston come up higher is good?Original Std. Ford 200 Pistons were a 1.511 C. H. generally a stock 200 short block (all years) will have a piston to deck height of .019. With the stock steel shim head gasket this gives a very good Quench Distance of .041. The regular oversize replacement 200 Pistons have a 1.50 C.H and puts them down the hole at .030.
Looks like your block might be a little thicker deck if you still have the OEM pistons. In any case if you decide to use those Australian Pistons and they stuck up .009 above the deck using a FelPro .050 head gasket will get you right back at a .041 Quench Distance again it should work out excellent. The Victor Reniz head gasket would also work well for a little tighter Quench making it even better at .035. Best of luck
If I were doing a new guides, Toyota valves would be great. But I did some conversions and 8mm is smaller than 11/32, so I have to find a larger valve. RIP.Yes!
Very good info in this thread. I, for one. Came up with the same conclusion, Ausie pistons from Summit. And the Toyota valves! What a Great idé! Got my Exhaust valves to Day, from a company in US, made in China and sold in Sweden.. Well traveled valves i say. Just have to ream the guides to fit, and open up the seats a tiny bit. I'll folow this closely.![]()
It gives you a line to follow when unshrouding the valves, so the chamber walls do not go beyond the cylinder wallsWhat does that measurement give me? Centerline to deck? I don't follow.
I saw your post about the log head you cut up. That was pretty slick. How's it running so far? What really causes the carbs to go out of sync? Because I have a 1977 Honda GL1000 with 4 carbs and have never had issues keeping them in sync.
