xrwagon
I have just removed my gearbox, clutch and flywheel to see where and oil leak s coming from. We had 3 sets of eyes on it on the hoist prior to removal and seeing i have already done a main seal, i fixed it last year, it hasn’t been a problem since, we had nothing on the flywheel face, clutch side but one run on the inspection cover side indicating a plug on back of block, i thought all welsh plugs were there for water, the one behind the camshaft i take it can leak oil? This is the only obvious place. To be sure is it recommended to pressure test the motor? I wiped down the rear main and back of block and will look tomorrow as i have no light now.
