200ci Headers? Or Are They Vee8?
They look like six headers to me. Only bifurcated. As for fitting your application, who knows. Good bet that they would I suppose. How many different headers did they make for the ford sixes?
soz again, but are they v6 headers then? becuase my engine, all six are from the same side? or will it still fit?
They are not V-6 or V-8. Look closely, the cut off is the siamesed #4 exhaust port that slips into the other section of the header. It will work on your 200 block.
As for clearances in the engine bay, you will have to decide on that. If they are inexpensive, what have you got to lose. Good luck.
Kirk '73 bronco
They don't look like they will fit to me; I have a clifferd single out header in my 64 ranchero and it's a close fit. Those look to me like the stick out further from the block than mine.
they look similar to the hooker header
when the headers are oriented correctly they will all be onthe same side
it is just a bad pic.
for best results i would get a coated header from FSPP
John
Those are Clifford headers I have a set just like them on my '64 Comet, what I don't like about them is they come out really close to the ground, I bought a FSPP header to replace them when I build my new engine.
See Ya,
Mike
