Hey everyone, how are you all doing tonight? Me... not so good. The chargers lost badly and the falcon does not start!
So here is where im at. I have a stock distributor, but not a load-o-headache. I checked the positive side of the coil and it is getting the full 12v (no resistor wire.) Then i checked the negative side to ground and there was only 1.5v. This was with the engine not turning, the key in "on," and the magnet in the dizzy that triggers my pertronix ignition REMOVED.
I then REMOVED the wire that goes from the negative coil terminal to the pertronix ignition. With the wire removed, the negative coil terminal had 12v under the same conditions as i stated above.
What does this mean? dead pertronix? With that wire hooked up, i should have been reading ~12v not 1.5v right? If more tests are needed to be done, please tell me what needs to be tested, im going to moniter this thread for a wile
I need my car tomorrow!
Thanks guys,
Moe.
Thanks guys,
Moe.
