did they make a intake manifold for these that the carb would bolt straight up like in picture without using adapter plate. maybe an industrial manifold. i’m looking for one Thanks
I have one from a 223 with the carb(single barrel Holley) if you want it?
If I don’t need the linkage you could have that also,
The exhaust heat riser is stuck shut but maybe a little WD-40 could free it
I believe it’s either car or truck just not sure why there are 2 different ones. But the one I need is the taller one it’s going on a ford tractor with Funk OHV conversion
