I am in the thinking stage of building a HamB rail. I'd like to run a Ford 6 but can only run a Flathead six or the 226 and 262 OHV engine as 1962 is the cutoff .
I could go flathead six and build a stroker 226 as Calf. Bill tells you how to--just use new rods instead of the olds rods.Might get lucky and find a 254 and stroke it the same way. But are there any Alum Heads for the Ftathead six out there that I don't cost an arm and a leg ?
I read a post were a guy was going to redo a 262 with 300 rods 292 60over pistons and a stroke to the crank. Sounds like a neat engine. Whats the stroke on a 262 ? The 226 is 3.6, but I don't know if the 262 is both a bigger stroke and bore. I also from reading on this forum see that the 262 is very hard to find.
Just thinking can I make more HP with a stroked flathead six--with Alum head or with a OHV 223?
