62Ranchero200
Greetings Ford Six Fans,
My 250 short block is almost completely assembled at the machinist! Only the camshaft installation remains, but there's an issue with that.
As the camshaft bolt is tightened, the center rear surface of the camshaft gear (see photo) is pulled up hard against the thrust plate. If the camshaft bolt was torqued to spec, the camshaft would not be able to turn because of the contact between that surface of the camshaft gear and the thrust plate.
Is there an additional piece that goes between the nose of the camshaft, inside the thrust plate, and the camshaft gear? I didn't notice one when I disassembled the engine, but maybe it looked like part of the camshaft itself. My machinist seems to think that there should be a spacer or ring between the camshaft nose and the camshaft gear. Please advise.
Uploaded with ImageShack.com
Bob the Builder
Uploaded with ImageShack.comThanks
Bob the Builder
