blakphi
All,
I have a question about camshafts and timing chain sets. Are all the 250 factory camshafts the same specs? If not where can I find the specs?
I also wanted to know if the timing gears on the 250 are similar the ones on the 302, in the way the gears were changed to retard the timing in 1973? In 1973 Ford changed the timing gears to retard the timing for either emissions and/or economy. On a 302 the camshaft is more or less the same from 70 up, so if you want a 73+ engine to perform better you can use the 70 gear set on the 73+.
Thanks in advance,
Thanks in advance,
