65_Vomit_Comet
My 1101 has a plastic nut that allows for power valve adjustment. I know you aren't supposed to touch it, but I'm looking for specs to check it as I'm uncertain if it's set correctly. The main issues I'm fighting is poor fuel economy, 13 mpg with a 72 main jet (I had surging at speed with a 68 so I went up to a 72 which cured that) and lack of power on acceleration compared to similar 200 equipped cars. I have good compression, my accelerator pump is adjusted to spec, and my timing is set to 16 degrees base.
65 Comet with a large log head and mild cam and 3.20 gears.
