Melling 626, 1173, whatever.
3.77375" over bore for 3.701" bore is just fine.
I use Chevy liners CSL331F, with CP brand XR6 turbo pistons. Same 3.632" bore as 3984 cc sohc and dohc Fords from 1993 to date, for 84 thou wall thickness. If you took your 4200 trailblazer out 20 thou, that would be about 74 thou liner thickness, so in our iron blocks, its all good after a 93.75 to 120 thou over bore.
Since the top is locked by a 195 thou ledge in the Chevy liner, I mill it back to 154 thou and use a totally loose 2 thou clearance, so the liners practically rattle.
Ford Corsair rods Rod Length 6.496" Journal Size 1.967, set on a destroked EF crank, 233 cube, 3823 ccs with 3.632 bore and 3.753 stroke
And 109 thou block topper two packed to the block, one Falcon X-flow gasket at 45 thou, another Apco 630 gasket at 45 thou for stock US 250 block deck. Then stock iron non cross flow head on cross flow block.
Kelford supplies the cc 285 style cam.
Everything is locked in, and the US liner engineering is great.
Nothing you are talking about bothers me.
See
viewtopic.php?f=1&t=71038&p=545177#p545177
viewtopic.php?f=1&t=69097&p=547664#p547664
NB// I stack two head gaskets, and apply a steel plate. That's 109 thou or 154 if you add the compressed Falcon X-flow gasket at the base.
The Aussies block plates 500 thou thick in the late 50's when stroking I6 Holdens from 132.5 cubes out to over 180 cubes with custom alloy heads, 36% bigger via a massive 187.5 thou over bore. As long as the ring lands didn't cross the new steel, no problem.
viewtopic.php?t=6557
See
