Why do people have to lungs? Because its impossible to have the area of a basketball court in your chest unless you have two bags. This creates more surface area, more flow loss, but better oxygenation
Skin friction decreases with size.
In the case of lungs, two bags beat one. In the street six or tow car truck, it is also the case, but for another reason; gas speed.
Despite two small pipes have more wetted perimeter than one large pipe, and are more restrictive, they promote signifcant low end torque and a sweeter sound.
The old Mannings channel flow has wetted perimeter of wetted area as a method of determining headloss, and let me tell ya, its conclusive. Dual pipes are no match for a bigger single pipe for peak flow.
Example:
On a little 200 cube six, two 2" ID pipes 12 feet long have a internal surface area of 6.283 square feet each, or 12.57 sq feet for both. It's cross sectional area is 0.0218 square inches each, or 0.044 square inches total.
The equivalent single pipe has to be a huge 2.83" diameter, and has an internal area of 8.89".
The peak gas speed on the smaller, larger internal surface dual exhast system is heaps higher than on the single pipe, which is where the extra torque comes in. A big single should not be the first option.
The reason for favouring the option of using a dual system is cost and the fact that an exhast system has to meet a a crtical flow speed. Going to a big pipe drops the flow speed and maximum torque, even though peak power increases. This is why engine programs development programs focus on dyno tuning dual pipes giving better torque. On cars with Watts links or fuel tanks in the way, a big single is often the only option. This is the case of Aussie Holdens with2.25" singles and 3.8 liter Buick engines, and also the XR6 Falcons, which have severe space limits becasue of the under trunk and seat restrictions.
Race exhasts don't suit road cars. If everywhere was Laguna Seca, we'd all have 3" single pipes.
V8 dual pipes are cheap, simple, and give lower restriction per dollar spent. Big pipes don't isloate noise well, fail to build up low end torque, and need more expensive mufflers.
The tip on Y-pipes is that any thing that is like a valve is an unaerodynamic restriction. The ones which don't allow a standing wave to travel back up the pipe work; the dual out headers to a H-pipe then to a dual have no restriction. Similarly, onn a V8, X and H pipes are fine. Y-pipes are a potential proplem that require specific design to eliminate a wave backing up to the exhast header at the engine. Angles which make it y and not Y shape work best. Ford Australia used tri-y headers on the 1971 Falcon GTHO to improve high end power with no loss in low speed torque.Despite a milder cam, it gaveimproved performance.I'm not sure about NASCARS but the AVESCO racers in Aussie X pips and dual pipes with huge success. No big phat singles anymore. You don't have to use them.
On the street, the back pressure must be reduced without a major drop in gas speed. Using two pipes halfs the back pressure. Using two big v8 pipes is the optimum. Any bigger, and you loose torque and gain noise. Why do 20 valve Toytota Celicas and Corolla's use dual pipes on 121 cube engines? To reduce the back pressure and make it sound nice.
We've all got a lot to re-learn about the good old six cylinder exhast. Chrysler Australia taught it all with the 14.4 second 1/4 mile 4.3 liter Valiant Charger E49.
Base six, 185 hp. Stock exhast, single branch. Optional 205 hp Pacer, dual out header.
Triple carb E38, single tuned length header with dual exhast. No change in exhast from the 248 hp six pack to the final 302 hp E49 six pack.
Same exhast on the 340 E55 Charger with the US 275 engine was very restrictive. The Aussies learned in 1972 that the right size exhast gives the right kind of power and torque.
On the race track, the little dual piped triple carb 302 hp 265 cube six out torqued and out accelerated the big 350 plus hp Cleveland 351 4V Falcon GT's. At the drags, the six did 14.4 second qaurters, the 351 a 14.7 second quarter.
Your sixes, with the right dual exhast system, should do the same thing. Performance single and twin cam Six inliner BMW's, Mercedes, Lexus, they all run dual out exhasts, not singles. Always have done.
