hey all i am new here i am an aussie
i've just about finished a 700hp build up of a aussie falcon i6
its a standard stroke 246cu in 4.0lt ohc engine feeding a turbonetics t72 with a t78 comp cover and wheel.
now i have been reading on these forums that there is a 300 cu in i6 in the states
now i know that the 250 x flow has the same bore spacings as the ohc engine so does that mean i could fit a 300 crank into the ohc block??
my plan is to fit a 300 cu-in crank with a set of custom h or i beam rods and a set of 20 or 30 tho oversized forged pistons all hosed in an au falcon bottom end (it has a crank girdle and a wider mains caps then all the previous models of aussie falcs)
see at the moment the turbo spools at around 3200 rpm and peak power is made at around 5700-5800 rpm so i'm only really getting 2500 rpm worth of fun.
now if i could bump the cappacity of the engine up another one litre or so the turbo should spool at around 2500 or a bit less.
i'd rather bump up cappacity then rev the engine harder as the ford i6 inherrantly is not designed to be revved -due to the fact that the motor is undersquare- which brings me to the next part of the problem.... if i go the 300 cu in crank (which will make the engine undersquare even more) it will not want to rev out to the 6000rpm limit i wish to run so its a catch 22 situation.
also the falcon engine has 12 counterweights on the crank (i know the x-flow had a 7 counter weight) so how many does the 300 cu in item have(same as the x-flow???)
well theres my thoughts on it, please if you have some input to give then do so as any help is always good!
cheers.joe.
cheers.joe.
