300 rod
my way
What does the 65-68 300 rod that has been used in 250 builds weigh? What's the part # ?
Thanks
Myway
That would be a very misleading bit of data for you because there is such a wide gap from what the lightest rods were in production to the the heaviest, that it could be 30-40 grams different from any rods you might find to start with. Rods with the big wrist pin may be heavier or lighter than the rods with the smaller pin along with other design changes that occured. Just too many variables to be very specific with an accurate answer.
The Casting or Forging number on an early 300 rod was C5TE-A (.910 pin) can't help you on the weight or part number though. Good luck :nod:
