34 ICH questions
I have an Offy tripple intake a 3 34ICH carbs. Can I get an electric choke for this type of carburator? If so then where? Also, all three carbs have idle cutoff selenoids and I will be running them in the progressive mode. Can I connect only the center carb selenoid up without having problems with the other 2 carbs since the idle circuits will not be used?
The hot setup is to remove the solenoids and replace them with fixed jet holders. you use a 65 jet in the center carb and 45 or 40 jets in the outer carbs.
Todd
Thanks for the info, do you happen to know where I could get my hands on some jet holders?
-Brian
We keep them in stock for 9.80 each, the jets we only stock 55-60-65
but can get other sizes same day before 11:00 am.
Todd
(714)496-2749
