I was planning on using my aussie speed intake with a 2v carb. I had gotten it for a different project but had to buy another truck for work before continuing on with the project. And now im considering giving up the first truck since the truck i got for work is exactly what i want. Plus with the carb cheater thats now out there by thunderhead 289, im wondering if that device would make carbs just as good as EFI.
I hear ya Dave. Forget the carb cheater. Put the Aussi on there, ok. (Will it fit with AC?) Part of my dissatisfaction has always been the ignition system. If you can keep the TFI ignition, it may do real well with the carb- I for one would be very interested in the results.
Recap: used a Summit HEI dizzy when the swap to Offy DP/Edelbrock500, until this year. Despite
countless tweaks with springs, weights, vacuum advance timing was never
exactly right. Now have a DS2 that Bill Amber curved for the EFI head. (And a Holley 390) It's way better, mileage is up slightly, but - hear this- the EFI head is ultra sensitive to timing AND that timing is highly affected by engine temperature. The current ignition is almost right- until the engine gets over 185*, then it pings. The factory timing table pulls
eight degrees of timing at 195* from 180*. Without a knock sensor, there is NO WAY to keep the EFI head at ideal timing. So carbing it and keeping the TFI computer ignition may give good results.
If you are truly shooting for max economy, I'll challenge you to try this, I will wager it improves economy: Change the 195* thermostat for a 180*. I am not exaggerating the exceptional economy of this truck with EFI. Flat, hot area like you're in. It got 22-24 mpg @ 60 mph AC on. E4 auto trans/ 3.08 gear. Repeatedly, on a monthly trip to Charleston, 75 miles. Went there and back on about 6 gallons of gas. It has a 180* stat. @ 180* the computer is running earlier timing than at higher temps. If it's too much, the KS catches it. This way the timing is always at max efficiency. @ 195* the computer may be leaving some some tune on the table with the 8* retarded spark.
