I've seen a 4-71 on a 202 with Cain fanimold, so I guess something similar might be possible for the Flagon engine. You'd need good bracing to prop it up! I think the Terra Chargers might be a better fit.
It can be done for sure but unless you are going to run it on methanol or figure out some way of intercooling the inefficient Ag blower then you are not going to make any decent reliable power. Pumping a few PSI of hot air into your engine is not a good situation.
