So I'm starting to research for internals for my 200 i6, and I'm wondering if I need a forged crankshaft for hopefully 200-250 hp and 10psi of boost (got alot of mixed answers online). Idk if my engine has been bored and forgot to check when swapping the cam, but I'll check when I get a 250 head put on it. And any other suggestions for this lmk because this is probably gonna take me 2 years of buying parts.
You’ve caught my attention. I’m really happy with my NA engine but I’m thinking about boosting it in the near future too.
I was just having a chat in the YouTube comments with a guy who’s channel is Barra Stang. He has a Barra engine that will be going in fairly soon because he discovered that a stock bottom end on a 200 is plenty good up to 10 lbs of turbo but it will let go at about 15 lbs if you get overzealous. He got overzealous.
His 200 engine had a stock bottom, Clay smith 6474 camshaft, his head was ported and polished to some extent and he had opened up the log to fasten the 2V mounting plate directly to the log. I think he was using a Holley Sniper system but I may be mistaken. I don’t know what horsepower he was producing. The cool thing about this guys setup is that he modified an EBay header to sweep forward into his turbo rather than using the cast iron manifold and a u-pipe fitting.
I watched another YouTube on a NA 200 with the Classic Inlines head, sniper FI with a 4 barrel throttle body and sniper controlled ignition timing and a camshaft that give a broad power curve (the videographer’s description). His channel is under mechtrician1. He has it set up for a very smooth dyno result that reaches 150HP and 175 ft/lbs torque. The curve looks very streetable. If an engine like that were boosted, it would probably reach your goal. I don’t know what the HP/LB ratio is with these engines but 10 lbs must be worth 100hp on a sorted out engine running computerized fuel injection and spark control.
The Hermes Motorsports one that
@bmbm40 suggested made 400HP and 500 ft/lbs torque with a log head and a turbo kit he pieced together before they got serious. He called that a very, very small turbo. He has a complete video describing everything he did. He put that video out about a month ago. It’s really worth checking out.
All that said, I’m not sure that you’re going to need an expensive bottom end. Just balanced with good bearings and rings. I would however use ARP or some other stud kit for the crank caps and the rods and the head as well. I’d get a cam that is going to work well with a turbo and of course, EFI and spark control.
