4V intake--too much?
I have scored some interesting parts and have this off the wall idea--most intrigueing is the fact i've never heard of it done before. Here's the plan. 78 200 with 264 cam(good vacumn version) dual outlet headers exiting after h-pipe out chrome lakespipes, head work for breathing and around 9.2-1 CR. assorted goodies dual chain, adjustable rocker arm etc. Basically untouched short block. Dura spark 2.-Srod-
Okay this is a daily driver not likely too push it too hard I have some autolite/motorcraft 2 barrels laying around and just scored some brand new 34 ICT's. The idea is mount a motorcraft 104 in the middle, decent low end response -good economy. Mount the 2 ICT's between 1&2 cyl. and between 5&6 cylinders. rig the ICT's so they only open at 3/4 throttle and higher.
Have zero concern about hood clearence (that's why they make sawzalls, hood scoops, and bondo).
The 2 barrell will let me drive everyday while i dial in the linkage for the ICT's. theory is bood venturi velocity from the 104 and top end support from the ICT's. Okay you hot rodders encourage me.
