Greetings All-
Trouble with my 66 Ranchero 200cid motor with a C4. My #6 cylinder is fouling out.
We can travel about 40mph with no problems, but forget the freeways. No visible smoke during operation, a little at startup. Wet Dry comp test shows #6 is a bit lower pressure than the rest, but not massively (10-15 lbs). Any suggestions? :idea: I've been told it could be the rings or valve seals. Gotta love the neighbor "motorheads."
.... it could be cancer or it could be a cold. The trans shop said it is not the modulator backing up through the vacuum line.
My IRS refund check is on its way and I want to fix this soon. Thanks!
-Dave
PS, Harleys I know, Ford sixes I don't!
-Dave
