60 amp 6 volt positive ground alternator
Mitch1947
Anyone out there had experience with 6 volt alternators. I may try one on my 1946 Ford two door sedan with flathead 6. I found some for sale on ebay. Thanks
I put a single-wire six volt alternator on an old Allis-Chalmers Model C tractor that I used to own; it was negative ground. Worked fine, except I had to rev that little engine up to max rpm (1800) before the alternator would excite itself and start charging, then it would keep charging at lower speeds too.
