After looking at all the old posts Im convinced it should work. I hope to get a 600 Holley in the next couple of weeks to put on my 250 2V. Ive just gone back through all the old posts on 600 650 mods to a 2V manifold ect. Even on "XT Falcons" engine with a fairly mild idle the 600 appears to work well.
Ill take the car out soon as it is and give it some curry and record times to see if the latter new addition does actually make a difference. If it doesnt work Ill move the timing gear around a bit (nine key way) to increase the duration. But Im expecting some gain without having to do this.
Only one problem I can see is that I will not be able to have the carb facing the normal way as its "wings" will stick out and hit my brake booster in the Cortina engine bay. Subsequently Ill have to turn it around which will mean the primaries will be off centre on the manfold and might prejudice the flow all to one side. I am hoping to get around this by trying to direct the flow toward the centre with a piece of half sectioned channel on an angle welded to the underside of the four barrel adapter to about 20 mm off the floor of the manifold?
I was considering dampening the secondaries but the carb re-builder I spoke to seemed to think that If I dampened the secondaries too much I may have trouble if I have innsufficient vacume to get the secondaries to work?
Just as a final note C.O.M.E racing recommend that a 465 or a 600cfm Holley be used in conjuction with the cams from their maximum efficiency range in a 253 Holden. The hottest cam in this range is a 204 at 50 which I estimate to peak at about 4000 rpm (although it will do more).I believe C.O.M.E come to a lot of there recommendations through stringent testing?
Any suggestions appreciated.
