All Big Six 6015MSD coil on plug conversion
Relates to all big sixes
Tbone3366
wanted to see if the TFI disi would work to control the MSD coil on plug box, this would be for a turbo application of course but i wanted to see if i could get a pip from the tfi to work instead using their distributor since i have a ton of TFI disis from EEC3 to EEC4 for the big 6
The 6015MSD needs a separate cam sync signal and a separate trigger signal and was set up to work directly with the MSD Dual sync distributor.
Secondly it is only set up to work with 8 cylinders.
I don't see a provision for 6 cylinders in the setup menu.
Thats what i wanted to verify,
