What's typically an acceptable high rpm for a 200? I've got an early Bronco with a 200 and 4.11's that I run 35" tires on. Well, needless to say, I've lost all the bottom end. I'm going to re-gear it and can't decide how low I can go and still be able to jump on the highway if needed. I've found a ratio calculator that says 5.13's will put me back in the range it came when it was stock, 4.11's with 28" tire. Should I go with the 5.13's or should I overrgear it a tad with 4.88's to build in some overdrive and drop the rpm's a little? Feel free to metion anything I may be overlooking in the equation.
http://www.dirtroadmagazine.com/gears.htm
