80Stang
Howdy, I'd like your opinions how this would work and suggestions to get best results out of it.
The whole thinking is based on that you can find the right advance to certain RPM (at certain driving conditions) by finding the peak manifold vacuum at that RPM. Right?
Naturally it is impossible to find it under varying loads but finding it at steady load seems possible and pretty easy.
I have means to control advance from the front seat by independently controlling the vacuum diaphgram of the dizzy. Also I have the meter to read manifold vacuum at all times. I thought I'd have a friend drive the car on a flat road thru a series of RPM levels and me finding the highest manifold vacuum for every RPM level by actuating the vacuum advance on the fly. I need to know (measure)
- initial advance
- centrifugals curve i.e. how much advance it gives thru rpm range
- how much vacuum applied to the diaphgram gives advance
and then it is possible to calculate the advance curve at the "sweet spot" where manifold vacuum was the highest for every RPM level measured. At least that would optimize the curve every time the driving condition is the same; same load, same gear, same everything...
Ok, put your knowledge into play. Would this be a way to a pretty good overall advance curve? Maybe knock appear while the manifold vacuum is still improving, then I'll just mark where the knock appeared and set the curve a pair of degrees lower at that point.
Weather you shoot the idea down or don't, I'll try it anyway. Got the gear, just need to get some other things done first as they didn't give us 28 hours a day.
- initial advance
