i wrote the following as part of a response to a A/C belt issue. Anybody thought about A/C refrigerants before?
I have a few ideas about using hydrocarbon (propane/isobutane/butane) mix for a/c, it is non-toxic, zero ozone effect, a 1 year atmosphere life. It's also dirt cheap and more efficient than both R12 (freon) and R134a. A true drop in replacement for those nasty chemicals. It is non-corrosive and perfectly miscible with both PAG and natural oils. As for the fire risk, there is about 300grams of it in the system (you use only a third compared to traditional refrigerants) meanwhile you got 60 litres of hydrocarbon in the boot.... All refrigerants are required to have oil finely misted within it, it's what lubricates the whole system especially the compressor. A rupture of the evaporator (inside the car) even with a non-flamable (but toxic) refrigerant still poses the risk of the fine oil spray igniting. Non-flamable oil, I don't think it exists.
Any thoughts/ideas appreciated.
I have made a vacum pump from a fridge compressor, pulls down to 28inches of mercury at 1000 feet above sea level. It already had a r12 compatible schraeder valve, too easy.
Dom
Dom
