No worries ET alloy, Fingers.
I tried loading Desktop Dyno an age ago, but my beloved wife wiped out a file ( after I told her it was okay...). A 33 mm alloy head port isn't a world beater, but its darn good for a stocker.
If your looking at the Aussie 250 2v, then the ports are huge. The old iron headed 1976 to 1980 X-flow has poorer, non uniform port shape, but is bigger than any X-flow alloy head by 3 to 8 mm in port diameter, depending on year.
I've not used the critical air speed or intake runner volume or port size to determine ideal CFM for a given application, but there is a critical flow formula, and it is suggested that if its over 265 feet per second at maximum revs, then the port is too small for performance. Others get past this by engineering cunning which I've foot noted.
What I use is the completed flywheel net figure with headers and exhast optimised.
I use a composite Aspiration ratio, load up 11 variables, and work out how critical each facet is. I've docummented this in some of my earlier posts.
The issue isn't that a 200 cfm port can't get 320 hp. It can, you just make it :
1)do more time on duty by cycling the engine more,
2)and raise the roof on the rev limit,
3)increase the vaccum reading under full power,
4) use scatter cams and rocker ratios (varying LCA's, running longer rocker ratios on outer cylinders to improve the poorly fed cylinders, some exhast valves may use smaller rocker ratios to reduce scavanging on certian cylinders).
The people from Argentina a some of the smartest around. They use a mixture of American parts with Latin passion, yet do it on a shoe string budget which would have us 'Rich Westies" starving. When I see one big 48 mm Weber 5 iches off the 2-bbl inttake, and a 183 cid engine with Chev pistons, special rods, special 2.76" cranks, and 1 port heads, I see the Lamborghini's Dallara, Ferraris Lamperdi/Columbo philopsophy of short stoke and huge bores. These engines don't hand granade blocks or cranks becasue they are under very little side loads.
A 250 2v would not like 7500 rpm for a standard 300 hour Ford durability test, even with a 320 degree cam and three 48 IDA's , but the engines the single duce 188/221's the Argentine guys run are very special, with little rotating mass, and some amazing work done with the six swinging legs on the crank.
For the 200, I'd be running the Iapel pistons and Brazilian 2300 Lima 5.2" 4" style rods which you get from SVO. That should allow 7500 rpm. The cam then gets custom made to add power after the CFM flat lines.
APT do this service for a cost if you can supply details. They are used to doing it for A-series engines and other formula races where the intake or heads have to be stock to compete. David Vizard sometimes uses scramble cams using Cranes services. This is high end stuff, about 0.001% of engine rebuilders would never get into it. Other companies (FSPP, Clay Smith, Crow Cams in Australia and others run standard grinds based on years of experience from customers who come to them again for repeat business. These guys can a picklist suitable choices for each cylinder, or APT could devise there own. The lift rates and master cams are already in existance.
6banger noted that engines that have heads that flat line before well before the peak rpm tend to hit a wall. The camshaft robs lower end characteristics, and then tries to build a purely top end engine. The head could loose maybee 35% flow on an aftermarket head, but a custom cam will regain the amount of hp lost by pushing the air flow speed to a super sonic levelb y making the car rev and suck more air through the carb.
The tradeoff is huge cam grind expense, and low speed power drop off.
