I want to build a 170 with a 200 crank to run in HA/GR and must use the stock head. This is an all out race motor that will leave the line at 3000rpm and go through the lights at 7000rpm. I'll be running a 280 Duration 480 lift Cam with zero deck height pistons (they may even be above the deck a little) for a 11 to 1 compreson ratio(racing gas only). I had thought about running three 170 or 180cfm Holley 1 barrels on a home made tri power setup. But I was looking through the Holley book I have and the Model 2110 "Bug Spray" 2 barrel cought my eye. It is a 200cfm 2 barrel and has a mounting flange that with 3 would put a barrel over each runner on the Log intake. Has anyone ever run three of these carbs on a log intake before?
Please give me you feed back. again I must run Period looking carbs and can not run a Holley 4 or 2 barrel or side draft carbs. idea:
