8) addo is right, you need a new charge wire, and high power stereo equipment, and other high amp draw devices are going to need their own feed wires, but the stock wiring system can be used with no problem. each device draws only a certain amount of current, and the regulator in the alternator only allows the alternator to put out the current needed.
