I know some guys who have ran them on the street. I have had dirt trackers run them for a season or two with no problems.
The key is to get the lightest piston possible. Not an easy task with sirup buckets for pistons.
However the rods for a BBF are beefier than most.
The next task is to keep the oil temp below 200, Also not an easy task with a street engine. It might be a little easier with that aluminum block.
The trouble with your application is it would be a lot of trouble to check your rods. When using them in race engines you freshen it often enough to be able to keep track of their condition. When you start to fatigue aluminum it will show up while measuring them.
You can check a the rods when new and record everything. Especialy the big end bore and length. When you freshen the engine you check the rods and compare the measurements. After awhile you will notice the big end of the rod will get smaller or distorted. Distorted is bad but smaller is not as bad. At a half a thousandth smaller you can remove the dowels (sometimes very difficult) and hone them back to the proper size, reinstall the dowels and put them back in. When they get to a half a thousandth again you toss them, make realy cool stearing colum and muffler mounts, or sell them on Ebay. The biggest problem I have seen with aluminum rods is after a trans failure or terribly bad tire shake or on dirt tracks that are rough tracks(most of them). These conditions add to the cycling loads.
They are a ptia but a possibility. I think the bigger gain would be to lighten the crank extensively and maybe run BBC rods with light pistons. You would have to consider the slightly shorter deck height, but you could stroke this thing to half of a 514
There are lots of aftermarket BBC steel rods out there. I am sure you could pick up a partial set real reasonably. Now that I think about it, the early 514 kits were built with big block six rods. The problem would be a partial set of stroker pistons.
HELP I am dreaming and I can't get up
Now for the voice of reason.
You have a lightweight engine. 8)
You are building a lightweight car. 8)
If you keep unsprung weight to a minimum there won't be a need to get out of hand during the engine build. 8)
If you look at HP per LB this thing in stock form will be fun to drive
If this thing won't keep a headgasket on it, how much of your investment can you recoup?.
If blow the engine, will your wife ever trust you again?
You did say roadster didn't you? These can be real fun to blow an engine in.
