Hey Guys,
Well I had originally said Clifford had cleaned its act up but I take those words back. Within the last 2 months I have had the following problems:
1) They sent the wrong carb adaptor so I needed to send back the old adaptor at MY cost. I then look at my credit card bill and they charged me shipping to send the right adaptor!
2) The gasket they provide with the valve cover is crap! I put the cover on and drove around the block only to come back and find that oil had leaked down the side of the block and onto the intake. All valve cover bolts were torqued properly and I used a good amount of RTV sealent.
3) About one month ago I started noticing a white milky-like substance on my oil dipstick. I searched but could not find the problem. Everything worked ok and I am planning on doing a rebuild this summer so I figured i'd let it slide and keep an eye on it. Well today I tried to pull off my breather cap (to add oil) and this time it wouldnt come off! I yanked a little harder and the oil filler neck came off! I looked at the glue and it was the white milky substance! Looks like the glue cliffy applied to my cover started falling apart after one month! The glue was inside the neck, inside my breather cap and on the oil dipstick...so I am assuming it is going through the engine also! I plan on pulling the cover this weekend to add a new gasket and was wondering what you would recommend to attach the neck? I plan on cleaning off all of the old glue and applying some type of other sealent. When I do the rebuild i'm most likely going to add the chrome valve cover like AzCoupes and Mustangaroos.
Sorry to complain but I thought i'd write this up incase potential buyers are looking into Clifford parts.
Mike
Mike
