It's been almost 2 years since I lost the shop space I was renting and made my last push to get the mustang back on the road, so I got it into the garage and started back in. I replaced half my valve seals that were wrong. I need to do two more things now before I button up the valve cover and could use some advice.
The valve cover was cracked up on the passenger side and some lite garbage got in there. I was thinking of stuffing the pushrod holes and the oil feed hole and spraying down the head with a cleaner of some sort, then blow it clean. Then squirt a little oil on the valve stems again. What would be the best way to clean it?
I want to disassemble and clean my valvetrain. Is there a place to get the plugs for the end of the shaft, or does anyone know the part number?
