Since the shortblock is done and assembled the machinist does not want to tap and thread the block as he is afraid of shavings getting into the oil passages and causing problems.
He wants to tal and thread the head to block hole.
This is so I can use SB Ford lifters and Buick V6 pushrods for oiling of rocker arms and shaft. Shaft will be dry film lubriant coated also to reduce friction and danger of galling.
I am/will be running the .080" solid copper head gasket.
