marquis83
Went down to the junkyard today and happened upon a 200 in a 81 fairmont futura.
It's a high mount starter block.
Someone took the carb and distributor already.
I managed to remove the valve cover and loosen all the head bolts, but had to quit as it was too hot out.
The exhaust is cut off already so no worries there.
What needs to be removed from the front of the engine?
Any suggestions on pulling it out? I'm going back tomorrow with a hammer and a pry bar.
