Anybody have Autlolite 2100 w/ Clifford adapter?
There's some interference between the adapter flange and the throttle shaft on the carb. Grinding will work, but I just wondered if anyone else had this problem before (and for $65, I would have expected it to fit). Plus, the bore on the adapter is slightly smaller than the head inlet. More grinding.
Also looking for some ideas/pics of throttle linkage. Since the Clifford adapter puts the carb sideways, the linkage has to be in the front or back instead of on the side. Do I need a cable setup, or is there something I can do with the stock linkage?
thanks in advance
Mark
Anybody? Throttle linkage pics or suggestions for the 2100?
Yes i had to do a bit of grinder work on the adapter for the throttle shaft end.I mounted my carb with the float over the valve cover thinking it would be good for heat reasons. How ever i have since decided i am going to flip it around as the idle adjust screws are a real PITA to get to that way. I just went ahead and put in a cable set-up.
