Simply because Ford did not design, engineer or manufacture ARP Products, ARP designers and engineers did. One thing that is often overlooked is that any manufacturer, whether its Ford, Chevy or any other has specs in their service manuals that only are relevant to the OEM products they design and engineer themselves, they do not apply to any aftermarket product from other manufacturers. Would you look in a Ford manual to set the valve lash on your Crane cam? No, you look to the wisdom of the company that designed and made the products for that information. That is all Ford is doing as well, they are giving you the recommended torque specs from the companies that made the bolts for them, Ford didn't make them. If you choose to use other fasteners or any products that are not OEM, then you cannot expect to use OEM specs, you have to use that companies recommendations to achieve the intended results for those products. Once you start using aftermarket non-OEM components in your engine, you begin to see that many of the OEM specs including tune-up and factory timing settings become irrelevant pretty quickly, as they too are also affected by the replacement of OEM parts with aftermarket products like camshafts, larger carbs, headers and other go fast parts.
