Autolite 1100 choke plate loose
notar61
Active member
Trying to get an Autolite 1100 in working order, but I can't figure out what keeps tension on the choke plate on the top of the carb.
Mine is kinda just flapping in the breeze. Is there maybe a spring or something I'm missing? Let me know if anyone's got any ideas.
I can try and take some pictures tonight. Thanks!
-Andrew
Check the black bakalite choke cover index setting usally they need to be set to 2 Rich (two notches past the center index) this gives you some spring tightness to the choke blade however in warmer weather the choke bade will be starting to open some in 70 degrees and higher so you might then check it early in the morning or late at night. Good luck :thumbup: :nod:
