Johnsondawg
I finally got around to installing my rebuilt 200 in my 66 Bronco with a C4 transmission. The engine is from a 68 Mustang and has an 81 200 head milled 60 thousandths to regain compression from the larger combustion chambers of the later heads. The C4 is from an 80ish fairmont and was built to merry up with my dana 20 transfer case I found a New Old Stock Autolite 1101 and got it installed. I also have duraspark II ignition and pretty much everything is either new or freshly rebuilt. The problem I'm having is getting this carb adjusted. I don't have any specs on where the float, accelerator pump, etc. should be set. I have my timing set at 12 degrees. It seems to idle great but when I hit the accelerator Hard it will stall every time even when its in park. I was not able to locate any sort of a vacuum leak using propane or brake cleaner. The accelerator pump appears to be squirting fuel in as it should. So what else could be causing the stalling? If I ease the accelerator in more slowly it won't kill it but it will stumble a bit on the way up. Can anyone provide me with some info/ specs about setting up this carb? My carb is like the one in this diagram that I found on here in another thread. http://s980.photobucket.com/albums/ae29 ... akdown.jpg
Any help getting this taken care of would be appreciated!
Thanks,
Jeremy
Thanks,
Jeremy
