Hello,
I posted a similar question a while back and a wanted ad as well,anyhow here goes.
Basically I'm looking to upgrade my stock 66 Mustang from the autolite 1100 and load o matic distributor to an Autolite 1101 and a 68 dist.I have an nos dist. The best carb to use I was told would have come off of a 69 250 and it did not have an scv (not easy to find).Well A friend of mine has a mint 1101 but it has an scv.My main question is,Can I plug up the scv port and use this carb with my 68 distributor? If so will this perform just as well as a non scv 1101?
Next question I've been told that the dual diaphragm distributors should only use one of the ports and the other should be blocked off? Is this true? If this is the case can I use a single port vacuum advance? Sorry for the long-winded questions I'm just trying to make perfect sense of this.Thanks
