I got the carb adapter to fit with a few very minor taps on the top of the valve cover and some grinding on the lower corner of the adapter.
Installed the new V-8 gas pedal and a lokar 36" cable set up.
Tweaked the carb idle and mixture settings today and got the timing all set at 10 BTDC.
Took it out for a test drive...got rubber in first gear...first time. HOLY COW!!!! I can't believe what I've been missing!!!!
Talk about a huge change from a crappy 1100.
A couple of questions:
- I can't find an air cleaner to fit . I tried one that is 2 1/2" from flange to top, hit the hood. Took off the top, the 2" filter and base plate hit the hood. YGTBSM. Any ideas how to get an air cleaner to fit on the carb? Maybe a ducted inlet?
- The carb makes a sucking sound as I'd expect, but it also sort of is making a rattling sound, not valve train related as it doesn't speed up when I rev the engine. Any ideas or is that normal sound for a 2100?
Pics soon to come of the install and throttle cable set up.
Steve-O
Steve-O
